Fan stuck on! Won't turn off!
  • freeride53
    • 11972
    As the title states, a few days ago I went to start up my car in the morning and the cooling fan came on. Weird, cause it wasn't even warm yet.
    The fan is suddenly stuck on and won't turn off.
    Like literally, if I go and turn on my car at any time of the day, with cool engine, the fan will come on when I flip my key to accessory.
    Bad t-stat? What does R3V think? I rarely used to hear my aux fan come on. Now it won't turn off!
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • roguetoaster
    Biggus Tippus
    • 7830
    Is your A/C button depressed? Try replacing the switch for it if that is not the case. New ones are not overly expensive.
    • freeride53
      • 11972
      Nope! Tried that .. it's off alright.
      • Ether-D
        • Sep 2011
        • 2838
        Bad thermostat on radiator or stuck relay (less likely...)?
        Originally posted by Andy.B
        I was born on 3/25…
        • uturn
          • Dec 2010
          • 1005
          Check that aux fan switch on the radiator?
          • freeride53
            • 11972
            Will check these out when I get home today, better beleive it!
            • AndrewBird
              The Mad Scientist
              • 11898
              Unplugging the wiring harness from the temp switch will tell you if it is the switch or not. If it turns off, then it is the switch. If it stays running, I'd say it was a stuck relay or the AC switch is shorted somehow.
