m42 ICV too quiet?
  • Boris3
    • Apr 2007
    • 441
    m42 ICV too quiet?
    So the ICV in my 325i has an audible hum/vibration when you turn the key, but the ICV in the 318is is so quiet the only way I can hear it is with a stethoscope and even then just barely. Is the m42 ICV supposed to be so quiet?
    The ICV ohms out correctly and I've cleaned it but no change, still quiet. Could be two different things but I've got a slight stumble at idle and I'm wondering if the ICV might be part of the issue.
    1990 325: track/racecar
    2003 330xi; project car
    2004 330i zhp: civilized car
  • kwill22
    • Apr 2009
    • 962
    I've had an ICV test fine and not work correctly though. Usually the ICV sticks when it's bad so if you tap it with a wrench or something while you're cars runnin it'll return to normal. Checked for vacuum leaks?
    DENY IGNORANCE!
    Schwarz 325-totaled
    brilliantrot 318i-daily
    Originally posted by mkcman17
    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
    • Boris3
      • Apr 2007
      • 441
      Took it off, cleaned and shook it. No change if I tap it. The quietness just makes me wonder esp since the 325i has a really noticeable hum.
      Idle symptoms are just the slight stumble. When the ICV went on the 325i it was more of wide swings in the idle. Not on the 318is though.
      Vacuum leak check? No smoke test or carb cleaner spraying yet. I've replaced all hoses since they were shot anyway. oil filter housing since it was leaking. Could be intake manifold gaskets.
      • kwill22
        • Apr 2009
        • 962
        My ICV is quiet also but I know I need a new one. When I start it sticks open. Idles about 1500. Then once I've hit second gear it'll start to work normally whenever I idle after that. It's annoying but I don't feel like spending the 150+ for a new one. Lol
        DENY IGNORANCE!
        Schwarz 325-totaled
        • Boris3
          • Apr 2007
          • 441
          Funny that the 2nd gear hit gets you back to normal. Warms up enough to loosen the buildup?
          My idle stays around 850 but with slight dips when it stumbles. So I guess it's working but the fact that it's quiet is still a puzzle. Saw a thread somewhere that said the Bosch ICVs hum but the VDO are quiet?
          • Delta
            • Oct 2014
            • 34
            When my ICV on my M42 was going bad I got wide rpm fluctuations, 500-2000 or so. Replaced it with a new bosch unit and it works great.
            You are right though, they are very quiet on the 4 cyl for some reason.
            Mine doesn't idle perfect either but I don't think you'll find an m42 that does. My tach doesn't flutter really but you can feel it in the seat. Also, when stopping after deceleration my idle sometimes dips and then goes back up to normal. I've learned to just accept it and move on.
            • ///M42 sport
              • 3952
              My idle is pretty steady
              • Delta
                • Oct 2014
                • 34
                Yeah? Mines not bad but it's not inline six smooth either.
                • ck_taft325is
                  • Sep 2007
                  • 6880
                  Mine's ridiculously steady. Dead steady.
                  Then randomly the engine will stutter and start to cough and try and die. It's amazing. Like watching a train wreck in progress. Throttle keeps it barely alive but it's almost like there's not enough to keep it moving. Then, it straightens out and it's fine. Go figure, 'eh?
                  Need a part? PM me.
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Sounds like the M42 mantra.
                    • DER E30
                      • Sep 2013
                      • 2349
                      This describes mine also
                      Runs much better when warm than cold...
                      -Christian
                      • DER E30
                        • Sep 2013
                        • 2349
                        I should also mention that I'm pretty sure my FPR wasn't hooked up from the last time I had the intake off and it runs much better now
                        -Christian
