My alternator belt just snapped, so I plan on replacing all the accessory belts. I also thought it may be a good time to replace the water pump and thermostat as well. I'm not sure when the last time it was replaced. I did some reading and some say recommend the metal one and some recommend the plastic/composite.
The two below seem to contradict each other so I'm not sure which one to go with.
Pelican recommends the metal pump
Tunermotorsports recommends the composite
Also is there anything else you guys recommend I check/replace while replacing the belts?
Thanks
Thanks
