m42 idle problem when cold
  • timmytwotimes
    • Aug 2012
    • 29
    my check lights on, when my car cold(first start of the day) it idles rough and wants to die, I cant give it gas cause itll die. I have to let it sit like that for a minute and then it runs fine.....whats deal? also after itll start up just fine after that.......wtf
    1991 318i m42
  • DiamondSchwartz
    • Aug 2013
    • 19
    Check your coolant temp sender for the DME. This tells the ECU how warm the engine is and adjusts the fuel air ratio to compensate for a cold engine.
    • ///M42 sport
      • 3952
      check relays, ignition coils...if you need cheap ignition coils I have spare.
