Temp cools down when driving
  • iso_hi
    • Dec 2014
    • 510
    My m42's temperature stays right in the middle on idle but recently I started noticing that when I'm on the highway the temperature almost goes to the 1/4th mark.
    It was running fine since I replaced the oil filter housing gasket a few months ago and recently started noticing my temperature being lower then usual. That has been leading to subpar mileage.
    Anyone have an idea what might be going on?
    1987 325 Turbo
  • ccsdo5
    • Mar 2013
    • 708
    Thermostat is stuck open I bet.
    -Dee
    5-lugged turbo 318is Barn car
    IG: @deebelmont
    • bmwman91
      • Oct 2004
      • 3134
      Yup, sounds like a thermostat issue.
      When you replace it, make sure to get the head and tstat housing immaculately clean before installing the new gasket. Also make sure that the small bypass groove in the housing (connects the 2 chambers) is clean and clear. Having that channel open makes bleeding the coolant system a breeze (versus a big pain in the ass if it is blocked).
      Transaction Feedback: LINK
      • iso_hi
        • Dec 2014
        • 510
        That's what I was assuming, hopefully my local shop can have the thermostat/gasket for me by noon since I'll be driving to Oregon late Monday.
        I'll report back.
        1987 325 Turbo
        • gearheadE30
          • Jun 2007
          • 3734
          Yep, same thing happened to me when my tstat broke one of the little support arms.
          Project M42 Turbo
          • iso_hi
            • Dec 2014
            • 510
            Just swapped out the thermostat, all is good once again.
            Thank you all for the help.
            1987 325 Turbo
