My 18is is consuming way to much fuel...
Thanks, the car is going to the mechanic this week, I'm going to ask him to check it outComment
Sorry no updates. Didn't go to the mechanic, some busy weeks right now, exams...
One thing i did discover, on one of the tanks i filled recently i decided to "not care" and just drive harder than usual. Not racecar like, but not caring about being below 3000rpm and etc. The difference in fuel consumption was not much by surprise. From 10,2 l/100 to 11,3l/100Comment
that "new driving" principle doesn´t work on our beloved m42´s tho.. if i have to drive like they say what´s best for MPG etc i have to shift around 2500rpm.
for cruising this is sort of correct, but when you´re driving on normal roads it´s better to keep off the pedal below 2000rpm, flooring it in the low rpm range will demand way to much from our revvy and torque-less engines. this can blow you milage too.
but still i think you have a bigger problem, best to check the exhaust gasses on amount of oxigen. lambda failure or something else can make you car run way to rich. this is a sort of failsafe made by bmw, better to drive an engine rich than lean in unknown conditions.Comment
Yeah true!that "new driving" principle doesn´t work on our beloved m42´s tho.. if i have to drive like they say what´s best for MPG etc i have to shift around 2500rpm.
Well the car is most likely going to the mechanic soon, some new parts also arrived (suspension arm or something like that, i can't say it in english lol)Last edited by MTD; 01-07-2016, 05:37 PM.Comment
Hey guys. I have another "symptom" that might give some clues on this problem.
Lately the car is having some problems starting up. Sometimes ill turn the ignition, electrical part all on, i turn the key... and nothing. I have to turn the electrics off and do it again. Sometimes 2 or 3 times. Once it starts cranking (i don't know if this is the right term sorry - english is not my 1st language) it always goes all the way and starts the car, but the problem is those times it doesn't even start "cranking".
Does this give any insight on the fuel economy issue?Comment
check your alignment. I just put in an e46 rack and drove on it for about 100 miles of mixed city/highway. went from 29mpg down to 20mpg. Car felt wayyy better after having it aligned and mpg has gone up.Hey guys, my 18is is consuming way too much, I do not know what's going on ... Lately I will always get 11 l/100 (Or 21.5mpg for the US folks). For the type of driving I do, and the engine that it is, it's way too much. 70% of my driving is in the freeway, in 5th gear at 2200/2500rpm. little traffic. Shifting at 3000rpm. Etcetc. I may do 1 or 2 agressive starts each tank of fuel, but thats it.
Given my type of driving, i should be getting much less fuel comsumption. I have no idea what it may be, since the car was revised and changed filters 1 month ago. Do you think?
Alignment is not the problem, i got it aligned about a month ago. Will also do it again in 2 weeks when i get the new wheels. What i do have is a slightly loose "suspension triangle" (i don't know how to say it in english right, but it's this part: http://i.ebayimg.com/00/s/NDU4WDQ1OA==/z/lh4AAOSwMmBViAI5/$_35.JPG)
But that will be taken care of next week as well, i already have the new parts with me. I suppose that shouldn't be the source of the fuel consumption right?
It blows hot airComment
When i got it aligned i did not know i had a problem in the control arm. Well,lets hope that it improves my mpgs when i put in the new ones *fingers crossed*Comment
Yeah it does shake. I don't know what is considered "nasty", but at high speed turns and bumps i can hear it rattling. If i drive "normally" it doesn't rattleComment
Hey guys, so the car is finally back from the mechanic today. It was currently doing 12.2l/100 (before mechanic). Things that were done:
-New control arms
-New bushings
-New wheel bearing for front left wheel
-Lambda sensor got cleaned up and fixed, wasn't working properly
-other sensors all around were "touched up" and overall priming of car
Things he noticed that will need fixing:
Somewhat urgent: front right shock, almost gone
Not so urgent : the catalyzer is getting a bit obstructed, not much right now but still
Also right now the alignment is fucked up, given the work he did.
So... Let's hope the fuel consumption drops! Filled a tank today, will report when I have results!Comment
