My 18is is consuming way to much fuel...
  • MTD
    • Nov 2015
    • 112
    #76
    No i did not. I probably should. any other tips?
    • unixnerd
      • Mar 2016
      • 20
      #77
      The best mpg I ever got in my 318iS was about ten years ago on holiday with my mother in the far north of Scotland, got 450 miles from a single tank!
      Usually I average around 32mpg (Imperial) or maybe a bit more.
      My BMW site: www.unixnerd.co.uk since 1996
      • MTD
        • Nov 2015
        • 112
        #78
        That's 8.8l/100, very good mpg...
        • d_elson0
          • Feb 2011
          • 242
          #79
          27-29mpg here. One day I'll try to better that. Maybe it's the funds style 5s or wheel bearings.
          What's the compression numbers we would like to see on these anyways?
          • MTD
            • Nov 2015
            • 112
            #80
            It's messing with me not being able to figure out why im getting bad mpg. Anyways, i'm ordering a chip in the next days, that should enhance the mpg a bit. Not the way i would like it though, i would like it to have a decent mpg on it's own.
            Any tips are welcome
            • 5Toes
              • 9836
              #81
              my m42 in great operating order, rebuilt head from a local ex-racer, and 155k is 180psi cold on a compression test. I suspect 200-210psi when hot but have not checked mine yet
              • MTD
                • Nov 2015
                • 112
                #82
                hey guys i come bearing good news! I tested a tank with my lambda sensor disconnected, and it dropped my consumption from 10.5 to 9.2 l/100!! What a difference! When i put in a new lambda sensor i can expect this value to drop even further right?
                • roguetoaster
                  Biggus Tippus
                  • 7829
                  #83
                  With the O2 disconnected the car should get worse mileage unless the sensor were totally broken.
                  Look under the wiring cover where the three relays are housed in the engine bay. Check to see if there are two single round connectors present, and if they are plugged in, or unplugged.
                  • MTD
                    • Nov 2015
                    • 112
                    #84
                    What i was told was that if the o2 sensor was in bad shape i could test it by doing this. If i got better mileage without it, it's toast. By the way, i deleted my cat.
                    I didn't catch what you said in the last paragraph. Pics? Why do you want me to check this?
