Omg dead m42
  • sketchkid
    • Dec 2015
    • 165
    Omg dead m42
    So today I put my cluster back in after good cleaning and put steering wheel back on. Then I change the spark wires go to start car nothing. Wheel is locked I can't get the ignition to turn now nothing. Could it be I put the wire in wrong 1,2,3,4??? If so which order should I do I sad and hurt she was starting fine before I did these things I don't want to take it to a shop to get looked at for something so minor and get charged out the roof. The head light and interiors come on that's about it nothing else.
    91 318is "under construction"
    2007 328i - daily
  • nk1221
    • Feb 2015
    • 56
    So the key won't turn? Or can you get the engine to turn over? If you can't turn the key I would think you put something on wrong while reinstalling the wheel.
    Sent from my SCH-R970 using Tapatalk
    • sketchkid
      • Dec 2015
      • 165
      Omg dead m42
      Ya I can't get the key to turn
      2007 328i - daily
      • RedTeam
        • Sep 2015
        • 15
        Is the steering wheel locked? Try shaking the wheel back and forth while turning the key to unlock the ignition.
        • sketchkid
          • Dec 2015
          • 165
          Yes it locked, should I take it off and put back on too?
          2007 328i - daily
          • jdt10768
            • Feb 2013
            • 484
            remove st wheel - then reinstall st wheel with ignition UNLOCKED (1st position, one click clockwise)
            • sketchkid
              • Dec 2015
              • 165
              Ok cool
              2007 328i - daily
              • sketchkid
                • Dec 2015
                • 165
                That worked thanks but now just horrible rough idle still and when I hit the lightly it loose power
                2007 328i - daily
                • nk1221
                  • Feb 2015
                  • 56
                  Double check you have the wires on correctly. Mine have confused me twice now for some reason.
                  • sketchkid
                    • Dec 2015
                    • 165
                    Yea I got those things defiantly right after a hour long put on & take off and put back on lol I think it's a vacuum leak but I can find a chart that show all the ones I need to check
                    2007 328i - daily
                    • roguetoaster
                      Biggus Tippus
                      • 7818
                      Look at my last post in your other thread in the M42 section, it has the info on the vacuum hoses.
