M40 vs M42 radiator
  • Heitzke
    • Nov 2015
    • 132
    M40 vs M42 radiator
    Got a 16" SPAL pusher and was getting all set to drop it in while doing the timing belt and:
    Realoem has them visually identical, but different part #'s. I've also read anecdotal evidence that the "m40 radiator is a little smaller" but not sure what the size difference actually is.
    It seems like others don't have problems fitting these fans on the M42 radiators. What size is the actual core on the M42? M40 core is ~14x15.5"-ish
    '89 318i Touring
    '90 Miata
  • roguetoaster
    Biggus Tippus
    • 7820
    M42 core is about 17.5x17.5".
    I am shocked that they would bother to have different radiators for those two engines.
    • Heitzke
      • Nov 2015
      • 132
      Haha well... dammit. It's such a tiny little baby radiator. I'm genuinely dumbfounded by this as well. I need to start up a thread of M40/42 differences that i've found so far with more tourings coming across.
      There have been a series of weird part differences.
      '89 318i Touring
      '90 Miata
      • fresh_TD
        • Aug 2013
        • 2457
        I also just picked up a 16" pusher (spal) that I'll be dropping in this weekend.. curved blades though.
        Sent from my SAMSUNG-SM-N910A using Tapatalk
        '91 318i (Alpine) - daily
        '88 325ix (Zinno) - drive here and there!
        • roguetoaster
          Biggus Tippus
          • 7820
          Any reason why both of you decided to go with pusher fans instead of pullers?
          • Heitzke
            • Nov 2015
            • 132
            Planning ahead for future space considerations mostly. Going to ride out the M40 for a while, but slowly looking around for m30/60/62 donor vehicles now.
            '89 318i Touring
            '90 Miata
            • fresh_TD
              • Aug 2013
              • 2457
              Pusher... to gain space between rad an engine. Will make easier for work down the road
              • fresh_TD
                • Aug 2013
                • 2457
                The one I picked up.
