m42 Code 1215
  • dmt16
    • Apr 2016
    • 2
    m42 Code 1215
    Hello,
    I bought a 92 318i convertible (140,000 miles) a couple weeks ago and redid the entire cooling system this weekend, the car came with a bunch of new parts so I figured I'd install them. Went ahead and did the thermostat, housing, water pump and radiator. Now it's throwing the 1215 code after I put everything back together and did the stomp test. I'm not sure what I did wrong. The only sensor I messed with is the crank position sensor to remove the thermostat housing. Any suggestions would be helpful.
    Thanks!
    Dane
  • iPee
    • Nov 2013
    • 190
    1215 seems to be MAF related, I'm going to assume you didn't touch/move the airbox.
    • downforce22
      • Aug 2009
      • 3193
      Last stomp test I did, my car threw this code but still runs good. interested to hear what others have experienced with this.
      • dmt16
        • Apr 2016
        • 2
        correct. Didn't need to mess with it. Only thing I did was open the filter box to see if I needed a new one...
        • Gerta
          • Sep 2009
          • 2119
          make sure reconnected the sensor cable.
          Parts Collector and Former Houndstooth interior junkie.
