M42 Road trip
  • sonomabimmers
    • Dec 2015
    • 802
    M42 Road trip
    in the middle of june me and this babe
    1991 318i vert
    are moving to Austin Texas going to be driving there and going to stop in san diego for a little bit first. getting her prepped for the long drive and recently i have done.
    Clutch/flywheel/bunch of little tranny seals
    rear main seal
    Guibo
    Drive shaft center support bearing/bushing
    Slave cylinder
    Brakes rotors
    Tires a new wheel hub
    intake manifold gaskets
    mess under intake
    Plugs and wires
    Chain tensioner
    coolant pipe
    steering coupler
    other little stuff I'm missing associated with those repairs ^^
    This weekend I'm also doing....
    New rack
    New bilstein sports and mounts all around
    power steering canister
    s.427 from another member m3ryan with new gasket,bushing and fluid.
    thats all I've got done so far.
    Any suggestions on repairs to do before i go and or parts to bring with me as back ups like radiator/hoses etc. would be greatly appreciated. thanks R3V
    i love bmws
  • Balleristic31
    • Aug 2009
    • 4198
    Looks like a good list! Make sure to get an alignment after that rack install though.
    -NICK
    • fresh_TD
      • Aug 2013
      • 2457
      The drive is going to suck with that 4.27..Good list of maintenence though!
      Sent from my SAMSUNG-SM-N910A using Tapatalk
      '91 318i (Alpine) - daily
      '88 325ix (Zinno) - drive here and there!
      • bmwman91
        • Oct 2004
        • 3128
        Seriously. At least it'll make it easier to obey the speed limits and reduce ticket chances lol.
        Make sure to keep a couple of quarts of oil and 2 gallons of pre-mixed coolant in the trunk. Oh, and a small tool set and some wire snippers (for the PS belt if the rack seals decide to blow). My trunk has all of this and more in it at all times, since that's par for the "Old German DD Preparedness Kit". Also, get a small first aid kit, just in case. You may never need it, but if you ever do you will be glad you have it.
        Transaction Feedback: LINK
        • roguetoaster
          Biggus Tippus
          • 7822
          My ideal spares list is as follows:
          Fuel pump/gasket
          Chain tensioner/washer
          2 meters fuel line
          FPR line
          Fuel filter
          Spare injectors
          Injector seals
          Oil drain plug/washer
          Trans drain plug/washer
          Diff plug/washer
          Axle boot kit/axle nut washer
          2 Trans mounts
          Alternator belt
          Voltage regulator
          Water pipe w/gasket
          2 Coolant block off caps/hose clamps for heater ports
          Thermostat housing gasket
          Engine ground cable
          Fuel pump/main relays
          Assorted spare fuses
          4 spark plugs
          Coil
          DME
          Longest spare spark plug wire
          Headlight bulbs/assys
          Tail light/turn signal bulbs
          4 lug bolts
          3qts oil
          Plastic tubing to fill trans/diff
          2 gal water
          Brake fluid
          Tire plug kit
          Metal/plastic zip ties
          Small floor jack
          Electrical repair kit
          Tools as needed (duplicates of vital tools too)
          Tire pump
          With that stuff on board you should be able to repair everything that you wouldn't need a tow truck for anyway. If packed well the stuff should eat up far less than 1/4 of the trunk space.
          • sonomabimmers
            • Dec 2015
            • 802
            thanks will do. i recently did that steering couple and got a year long alignment with firestone
            i love bmws
            • sonomabimmers
              • Dec 2015
              • 802
              thank you ya its been hard on my wallet and ya the diff will not be great for the long drive but its ok the car has a open 427 stock in it so I'm used to it. its a weekend car otherwise.
              i love bmws
              • sonomabimmers
                • Dec 2015
                • 802
                keeping the vert diff ratio. good call on coolant and oil. ill have all my tools in my friends truck thats driving with me as i am moving so than god for that. and first aid always safety first
                i love bmws
                • sonomabimmers
                  • Dec 2015
                  • 802
                  Fuel pump/gasket
                  2 meters fuel line
                  FPR line
                  Fuel filter
                  Spare injectors
                  Injector seals
                  Diff plug/washer
                  2 Trans mounts
                  Alternator belt
                  Voltage regulator
                  Water pipe w/gasket
                  Engine ground cable
                  4 spark plugs
                  Coil
                  DME
                  4 lug bolts
                  3qts oil
                  2 gal water
                  Brake fluid
                  Tire plug kit
                  Small floor jack
                  Tire pump
                  tire plug kit, fuel line, belts, 2 Coolant block off caps/hose clamps for heater ports, thermo house gasket,relays and fuses, coil, diff/trans filler, lug bolts, tire pump, dme, metal zip ties, fuel pump are absolutely great ideas thank you so much this list is exactly what i needed to see. its all great ideas but those especially i completely overlooked thank you. and i agree should take up minimal space and I'm shipping another car thats gonna be packed with most of my shit.
                  i love bmws
                  • roguetoaster
                    Biggus Tippus
                    • 7822
                    If you take it you'll probably not need it!
                    The 4.27 should be fine for the drive. I've had a 4.45 in my 318i for over a year and have only suffered a very small decrease in MPG. Sure, it runs at higher RPM on the highway, but the trade-off is being able to easily pass people in 5th and fun burnouts!
                    • Gerta
                      • Sep 2009
                      • 2119
                      Fuel pump/gasket
                      2 meters fuel line
                      FPR line
                      Fuel filter
                      Spare injectors
                      Injector seals
                      Diff plug/washer
                      2 Trans mounts
                      Alternator belt
                      Voltage regulator
                      Water pipe w/gasket
                      Engine ground cable
                      4 spark plugs
                      Coil
                      DME
                      4 lug bolts
                      3qts oil
                      2 gal water
                      Brake fluid
                      Tire plug kit
                      Small floor jack
                      Tire pump
                      I dig it. Thanks!
                      Parts Collector and Former Houndstooth interior junkie.
                      • sonomabimmers
                        • Dec 2015
                        • 802
                        i agree i had the option to get a 410 lsd but i opted for this because i can't imagine the vert m42 with any less guts and mpg I'm not worried about gotta pay to play i always say. I'm on lookout for a 445 always they never come up tho
                        i love bmws
                        • getouth
                          • Jan 2010
                          • 3343
                          Fuel pump relay and fuel pump, windshield wiper relay, these will leave you in a bad spot.
                          FEEDBACK:
                          http://www.r3vlimited.com/board/showthread.php?t=316212
                          BMWCCA #398608
                          IG @yagayo38
                          "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                          • Codym42
                            • Mar 2013
                            • 611
                            Fuel pump for sure. That left me stranded once.
                            Also how old is the cooling system? Might be a good idea to go ahead and replace some of those parts if they're old.
                            '90 325i - 5 speed coupe
                            '05 330ci 6MT ZHP
                            • sonomabimmers
                              • Dec 2015
                              • 802
                              winshield wiper relay is pure genius i never would have thought of. thanks a million
                              i love bmws
