M42 fuel injectors
  • sketchkid
    • Dec 2015
    • 165
    M42 fuel injectors
    Hey guy how in the hell do I get them off the rack I'm trying to take the off to clean or replace but they don't budge I tried in clipping them too should I just have it lol more tugg?
    91 318is "under construction"
    2007 328i - daily
  • roguetoaster
    Biggus Tippus
    • 7796
    Hey guy, u get dem off by pullin hardr.
    • fresh_TD
      • Aug 2013
      • 2457
      Someone needs to hit the gym
      Sent from my SAMSUNG-SM-N910A using Tapatalk
      '91 318i (Alpine) - daily
      '88 325ix (Zinno) - drive here and there!
      • bmwman91
        • Oct 2004
        • 3128
        They are off of the lower manifold now, correct? If not, take them off with the manifold because yanking on them to get them out can cause the pintle cap to fall off and go into a cylinder.
        If they are just stuck in the fuel rail...like the others said, just keep pulling and twisting. You will also want to replace the o-rings, and when you reinstall them you should use an "o-ring safe" silicone lubricant to slide them in so they don't bind or tear.
        Transaction Feedback: LINK
        • roguetoaster
          Biggus Tippus
          • 7796
          The voice of reason, hold the snark.
          If they're still in the lower manifold you can try prying with two implements from opposing sides while standing on a board passed between two runners to keep the manifold steady. Same method can work on the rail side minus the board.
          • Dust2glory
            • Sep 2015
            • 25
            I am assuming you took the retention clips off the tops....
            • Reub_e30
              • Apr 2016
              • 145
              We hope.....
              Daily: 06 Chevy Colorado (wannabe racetruck)
              Drift/Track Car: 91 Bmw 318i 4dr
              • sketchkid
                • Dec 2015
                • 165
                Lol yes I did take them off. I'm try again later this week
                2007 328i - daily
