M42 Timing
  • CFeld
    • Jun 2016
    • 102
    M42 Timing
    I have pulled my m42 from the car I just bought. None of the belt tensioners were in and I had to pull the camshafts and other stuff anyways (you can see my other threads one why that is). I have read and understand how I am supposed to align the cams for when I put the timing chain back on, but I have no idea with the engine on the engine stand how I am supposed to know where tdc is on the crank.
  • bmwman91
    • Oct 2004
    • 3130
    See the last diagram in my first post.
    There is a notch in one of the teeth on the crank damper wheel, and it aligns with the arrow that is cast into the front of the oil filter housing. Additionally, you can (and should) pull plugs 1 & 2 and stick a wooden dowel down in there and make sure that there is an 81mm height difference between pistons 1 & 2 since it can be hard to align the notched tooth with the arrow.
    Transaction Feedback: LINK
    • Gerta
      • Sep 2009
      • 2119
      OP - Some really good info right here ... bookmark them all:
      Brandon's Page: http://www.esatclear.ie/~bpurcell/
      bmwman91's Page: http://bmw.e30tuner.com/
      M42 Club: www.m42club.com
      Parts Collector and Former Houndstooth interior junkie.
      • 5Toes
        • 9836
        if I were you, pull the plug on cylinder 1 and insert an extension, find approximate TDC and then insert the flywheel lock pin. you will have to wiggle the crank back and forth to get the pin to fully seat but this is gonna be the easiest way.
