Need source for upper intake manifold
  • z28
    • Oct 2014
    • 362
    I have a 91 m42 e30 and one of the longer upper intake manifold studs is broken and I want to replace it but I cannot find a source for it. I need the m7x85 stud, the problem is that its been discontinued and I cannot find it. I was wondering if any of you can help me out with a source for it, thanks.
    First e30 - 1991 318i 4 door
  • roguetoaster
    Biggus Tippus
    • 7830
    You mean the lower manifold has a stud broken? Probably the most readily available solution would be getting a new (used) manifold, which should run you all of ~$20, even if you only want it for the stud.
    Alternately you could buy threaded rod for ~$15 and cut to fit. Or you could get someone like me with a plethora of manifolds to send you one stud, which would end up ~$15-20 with shipping.
    • ahlem
      • 369
      A meter of M7x1.0 is $11.25 from McMaster.com
      • uturn
        • Dec 2010
        • 1010
        BMW still has m7x95 studs. You can use a die and cut some more threads then trim the excess length.
        Pn 07129901481
        From an e36 m50 motor
        • z28
          • Oct 2014
          • 362
          Thanks, but Im trying to find it as cheap as possible because I want to eventually swap the engine to something more fun. The rod idea is pretty good though.
          Thanks, I was trying to find the cheapest rod out there.
          Pn 07129901481
          Nice, thanks for the pn I am ordering today.
