New Fan Clutch - Still stopped by roll of paper
  • boxy30
    • Mar 2015
    • 80
    Hi guys,
    My 318iS was running hot during standing traffic so I found a way to test the fan clutch was to jab a roll of paper into the fan and see if it stops the fan. It did, so i replaced the fan clutch this morning with a new unit. When cold, the paper no longer stopped the fan. When up to running temps tho, the paper still stopped the fan. Did i get a bad clutch..? Also, still see temp gauge creeping up when sitting still.
    Thanks for your input guys.
  • roguetoaster
    Biggus Tippus
    • 7830
    Recently replaced the fan clutch in my daily. The old clutch would be stopped almost immediately when warm by ~4 sheets of newspaper rolled up loosely, never checked it when cold. The new one can also be stopped by the same paper, but it isn't a quick or reliable stop.
    Be sure that you've bled your system (worth doing again if temps are creeping), that you don't have a weird leak (check your hoses for bulges, inspect the coolant pipe), that the radiator isn't blocked internally or externally, and that the alt/WP belt is tight.
    If a video of the new one in my car after 600 miles would be helpful I'll get one.
    • AndrewBird
      The Mad Scientist
      • 11898
      If you are overheating, there is a different problem than the fan. You should be able to run in 90ยบ weather with no fan and not overheat.
