replacing water pump, what else should i be doing?
  • Joerdan23TN
    • Apr 2012
    • 230
    I am replacing my water pump.
    I am just wondering, since i have all belts and fan removed, what else should I be considering doing or looking at since I have the front end broken down to this stage.
    thanks in advance!
    91 E30 318is
    99 E36 M3
    05 E46 ZHP sedan
    66 Impala Lowrod
  • TobyB
    • 5298
    Belts, hoses, timing chain guides/tensioner sprocket, belt tensioner...
    t
    • Gerta
      • Sep 2009
      • 2119
      thermostat, coolant flush. of course new gaskets on the timing cover, etc ... I really inspect the timing case and the sprockets too ... if you have the early e30 timing sprocket then you might want to replace that too.
      Parts Collector and Former Houndstooth interior junkie.
      • iPee
        • Nov 2013
        • 190
        It's a little bit out of the way but I'd recommend changing the plastic coolant pipe on the side of the motor as well. Mine just snapped off when I went to touch it. If you are going to do that may as well do the mess under the intake procedure too.
        • TobyB
          • 5298
          Oh, yeah, I'll second the 'I just blew up my motor' pipe. That thing's a time bomb,
          and for $12, not worth NOT doing. It's a little like the timing belt on an M20
          t
          • NYCDelphin
            • Aug 2016
            • 223
            any pic of this pipe?
            • roguetoaster
              Biggus Tippus
              • 7830
              It's the pipe that comes off of the block, behind the oil filter canister.
