Rough Idle, can't hold rpms
  • Sladek
    • May 2016
    • 228
    I took starter fluid and checked everywhere for vacuum leaks. I've got new gaskets on the upper and lower and throttle body. previous owner already did the mess under the intake clean up but I went in and replaced those hoses anyway. if I try and hold the rpms at anything above idle, after a few seconds they will drop and the engine almost stalls. injectors aren't leaking and my only other guess would be something fuel related? I bought new mustang injectors so maybe it's the fuel regulator or something?
    before all this it was running but had a fuel leak from what I believed to be the two short hoses under the intake manifold but after trying the old injectors again it leaked around one of them so that oring mustve been bad. so with that info when the new injectors are in and not leaking I'm down to icv or fuel pressure regulator/something fuel system related
    I also at one point got the 1262 code for the icv, but it's now back to 1444
    before doing this I also changed the valve cover gasket but I don't think it's related afaik
    sorry for the long winded paragraphs just trying to provide as much info as possible to try and solve this quickly
  • squidmaster
    • Aug 2011
    • 2666
    does it drive otherwise?
    • Sladek
      • May 2016
      • 228
      haven't moved it out of the garage, been working on various things on it for a few months. I would guess it wouldn't since I can't make it hold a constant rpm on throttle before it starts choking
      • roguetoaster
        Biggus Tippus
        • 7818
        If it runs fine at or near WOT try a different TPS and an O2 sensor if the stall occurs only when up to temp.
        • Sladek
          • May 2016
          • 228
          would it still be this if its at every temp and cant hold WOT? haha trying to minimize parts throwing
          • squidmaster
            • Aug 2011
            • 2666
            At this point you're just looking to trouble shoot. It could be: CPS, AFM, ground connection, or the coil. The o2 probably wouldn't hurt it that much, but you can always test that by just unplugging the o2 and seeing if any difference is made. The stock software should run stock injectors on a stock car pretty well without any o2 feedback. Well enough to see if that was your problem at least.
            • Sladek
              • May 2016
              • 228
              could it maybe be water in the gas tank? we did have a pretty large change in temperature this weekend
              • squidmaster
                • Aug 2011
                • 2666
                Are you losing any fuel when not driving the car? Gas evaporates pretty quickly, so if you did have a hole in your tank, you'd definitely be noticing fuel going missing.
                • Sladek
                  • May 2016
                  • 228
                  all the fuel leaks that I know of are fixed and no leaks. I've only got about 1/4 of a tank in it
                  • roguetoaster
                    Biggus Tippus
                    • 7818
                    Yeah, I was just thinking that the car thought you were at WOT for some reason any time off of idle, and enriched the heck out the mixture without air flow to compensate. Granted, this shouldn't happen when the AFM disagrees.
                    What's the exhaust smell like when running?
                    • Sladek
                      • May 2016
                      • 228
                      it smells pretty rich of something but it also has no cat thanks to the PO. I'm assuming it's got to be something under the hood since that's all I've messed with since I started it last and it ran like a champ
                      • Sladek
                        • May 2016
                        • 228
                        no luck with the ICV replaced. still the same thing as it seems like it runs out of gas if I try and rev it up and hold the rpms. haven't had a chance to check fuel pressure yet
                        and it still sounds lopey and starts to try and stall
                        • Sladek
                          • May 2016
                          • 228
                          so I changed back to the original injectors and that helped a little bit over the mustang injectors. i still have a lumpy idle.
                          I hooked up a fuel pressure gauge and took a video. anyone have any thoughts?
                          Sorry, we couldn’t find that page
                          • Sladek
                            • May 2016
                            • 228
                            I tried taking it around the block. got out of the garage and it fell on its face. had extreme hesitation and eventually just stalled not 50 ft from the garage. the spec for fuel pressure is 43psi and idling I'm low. anybody? bueller?
                            • squidmaster
                              • Aug 2011
                              • 2666
                              The idle sounds almost like timing is off
                              but the rest of the issues sound like bad AFM.
                              try disconnecting the AFM and see if anything changes.
