Removing and reinstalling m42 valves
  • jrobie79
    • Mar 2006
    • 2526
    So I'm getting my head resurfaced and taking the valve train apart would save me a boatload as opposed to having the machine shop do it. I have searched to no avail, how do you remove and reinstall the valves? Is there a trick? Special tools? Anything else I should look at while I'm in there?
    1991 318i ---- 308K - retired
  • ahlem
    • 369
    You need a valve spring compressor, a magnetic parts picker upper to catch the keepers and a clearly labeled board with holes drilled in it to keep the valves in the proper order.
    Youtube will have a number of how-to videos that should answer your questions.
    Be sure to work on a padded surface so you don't scar up your mating surfaces.
    A socket to tap the top of the spring retainer to loosen the keepers and you should be good to go.
    • TobyB
      • 5298
      I found that getting the right valve spring compressor was the real trick- a lot of the generic
      ones aren't designed for such a small keeper in such a deep head.
      At the end of it, I made one out of some pipe and a bar clamp, which took a lot of time,
      but no money. SHop around- you really want a tube that pushes down on the keeper
      while giving you lots of room to fish out the retainers. And a dead- blow hammer
      used gently helps break them loose, as the retainers wedge into the keepers.
      The first one takes forever- by #4, you're good, by #16, it's easy.
      t
