Idle control valve-M42
  • rebecca_m
    • Dec 2016
    • 1
    so recently I've been having problems with my e30, I'll drive it and it'll randomly shut off while driving, but start right back up. Usually happens when it's not in gear and it's just sitting idling like going down a hill in neutral. I'm currently cleaning my ICV and from what I understand I'm supposed to hear it rattle and no matter how much I clean it, it's not rattling too much. Seems stuck. Any help would be great...
    Also would a faulty alternator cause my car to idle rough/die? I mean I just recently replaced it.. seems to be ok because I did some tests on it..
  • Sladek
    • May 2016
    • 228
    idk about rattling but when it's plugged in and the car power is turned on it should buzz. at least that was my understanding when trying to figure out if mine was bad or not
    • g.ruff561
      • 1268
      Check alt belt to see if it's tight. Also check ground cable. Idle valve should rattle only when it is off the car., in your hand and you shake it. However it still could be sticking while in operation.
      • unixnerd
        • Mar 2016
        • 20
        That could be a bad relay, my 635CSi did that. Try new Motronic and fuel pump relays.
        My BMW site: www.unixnerd.co.uk since 1996
        • d_elson0
          • Feb 2011
          • 242
          How open does the door on the valve open? Mine will fully close but
          Barely open (maybe about an 1/8inch). And is in an open position when not plugged in.
          • roguetoaster
            Biggus Tippus
            • 7830
            Not sure if it's a linear actuator with a camming action or a gear output motor, but it really doesn't matter as they pretty much work or not as long as they are reasonably free of gunk.
            • d_elson0
              • Feb 2011
              • 242
              Gotcha. I
              Think I may buy a new one. It doesn't hum, and the door definitely doesn't open all
              The way. Pretty
              Gummed up even after a can of carb cleaner was use. Hopefully that, new gaskets
              And
              Vac lines will
              Solve my bucking/hesitation issue.
              Thanks for your response
              • e30davie
                • Apr 2016
                • 1788
                Is it a 3 wire bosch one? If so you can make it open and close putting wires to the battery.
