Where does the M42 oil dipstick fasten?
  • jaredmac11
    • Sep 2007
    • 253
    I converted my e36 m42 oil pans to e30 m42 oil pans (for fitting with my subframe) and I'm not 100% sure where the dipstick fastens since its shorter. I am trying to use the e30 dipstick with the e30 oil pan so it all should be good.
    Also if anyone has any tips with getting the o-ring in without crushing it, Im all ears...
  • roguetoaster
    Biggus Tippus
    • 7830
    The E30 dip stick has a bracket that bolts with one bolt to the front of the alternator bracket.
    Put the o-ring on the dip stick tube, insert tube in to hole, rotate/press down, shouldn't damage the o-ring at all.
    • mike.bmw
      • Dec 2015
      • 1777
      What roguetoaster said. You can kind of see it in this photo:
      • jaredmac11
        • Sep 2007
        • 253
        I didn't think the early and late m42 were that different but I'm definitely not seeing a good bolt to join to.
        I think I'm just going to shorten the e36 dipstick and see if I can mirror them. Otherwise see if I'm missing something....
        • roguetoaster
          Biggus Tippus
          • 7830
          They are very different when it comes to dip stick tubes.
          The early one looks like this:
          The late one & M44 one looks like this:
          They are clearly not compatible, with the early one fastening to the oil filter housing, and the late one to the intake manifold IIRC. If you shorten either then you'll have a dip stick length issue and probably won't be able to check oil level. If I were you I'd just make a bracket that allows the tube you are using to mount somewhere in a fairly solid manner.
          • jaredmac11
            • Sep 2007
            • 253
            Bracket makes sense to me. I was hoping to get it in proper but it's pretty clear somethings off. And yea, I pulled out the e36 dipstick from storage and it is wildly different.
            Found a better picture:
            I think I was putting it in too far.
            • bmwman91
              • Oct 2004
              • 3134
              That's what she said?
              Transaction Feedback: LINK
              • mike.bmw
                • Dec 2015
                • 1777
                I'm glad I wasn't the only one who immediately thought that. ;D
