I was testing my air flow meter (and other things) to troubleshoot a 1222 code and low-power, engine-dies-under-high-load problem.
How should the resistance between AFM pins 1 and 2 change as you move the AFM internal vane from closed to open? E36 Bentley's explanation is vague: "Resistance should change steadily without interruption."
My readings bounced around a lot, but were ~1200 ohms with AFM vane closed, decreased to ~400 ohms with vane barely open, then increased to ~700 ohms with vane mostly open.
