Base Tune for Megasquirt
  • gespinal0301
    • Jan 2011
    • 317
    Hey guys, just wondering if anybody has a base tune floating around. I just finished testing my MS3X and everything seems to working. Just need a base tune to really dive deep into testing.
    From there I'm making a plug & play adapter board, then I'm going to 3D print an afm connector and O2 connector so I can run those through the stock wiring ;D;D
    My Daily Driven 318is
  • bmwman91
    • Oct 2004
    • 3133
    You can try to 3D print a 7-position connector for the AFM plug, or you can just buy a housing and some pins. The PN's are 12521718125 for the plastic housing and 61131376191 for the pins (you will need open-barrel terminal crimpers). Or at least that is my recollection (I built a MAF conversion and used these PN's to build a nice OEM adapter).
    Transaction Feedback: LINK
    • gearheadE30
      • Jun 2007
      • 3734
      I don't know how MS2e maps compare to MS3, but if you PM me your email, I can send you my cal as something to start with. I'm boosted, however you can just turn off the table switching and change some of the engine constants for something to start with.
      Project M42 Turbo
      • gespinal0301
        • Jan 2011
        • 317
        I was thinking bout 3D printing it since I could never find the connector, but isn't it a 5 position connector? Im stuck in a hurricane so I cant really check right now lol
        Sending it now thank you!
        • bmwman91
          • Oct 2004
          • 3133
          The AFM only uses 5 of the 7 positions, but when you look inside the connector on the harness you will see 7 terminal positions.
          • gespinal0301
            • Jan 2011
            • 317
            Perfect! Thank you!
