PLEASE HELP diagnose another no-start issue (with video)
  • BHT2109
    • Sep 2016
    • 68
    Hey Guys!
    I'll try to keep to short: Drove from NJ to PA and back about 2 months ago, parked it, and went out a week later to find that it wouldn't fire. The engine seems to turn over, but honestly the sound coming from the engine as I turn the key is something that I've never heard before. I just need a little help diagnosing what may be the problem. PLEASE WATCH THE 30-SECOND VIDEO FROM FLICKR:
    https://flic.kr/p/ZB56my
    Here's what I've done so far to try and fix the issue:
    -New Crankshaft position sensor
    -New spark plugs
    -Tested for spark (all 4 wires delivered spark)
    -Sprayed ether into air intake.
    -Jump start (battery seems fine)
    -New Fuel filter (actually did this a few weeks before the non-start issue).
    I suspect that this is fuel-delivery related, but I really don't know enough about the M42 engine yet to make that determination. (Although, if fuel was the problem, wouldn’t spraying starter fluid into the intake get it to come to life, even if only briefly?)
    Does the sound the engine is making sound familiar to anyone? Can anyone point me in the right direction? Should I invest in a multimeter and/or a fuel pressure gauge?
    Thanks so much for your help!!!
    Ben
  • bmwman91
    • Oct 2004
    • 3129
    When you say you sprayed ether into the intake, where specifically did you spray it?
    Transaction Feedback: LINK
    • BHT2109
      • Sep 2016
      • 68
      I undid the air filter housing, then sprayed into the intake tube toward the engine (obviously) for a few seconds. Why? Should I try it directly into the throttle?
      • bmwman91
        • Oct 2004
        • 3129
        If you removed the filter box and the air flow meter, then the no-start might also be due to the fact that there is no air meter The car can run without it, but very poorly, so that might have been an added factor.
        Do you have a voltmeter? There are a couple of things you can test to see if the fuel system is getting power.
