M42 with MarkD chip
  • slowmoe30
    • Nov 2017
    • 30
    M42 with MarkD chip
    Has anybody bought and installed the 91 or 93 MarkD chip on their M42?
    What results are you seeing on a dyno? Or at least a butt dyno?
    Any side effects noticed? Fuel economy? Idle?
    If installing this, would a tune be necessary afterwards?
    Clearly thinking about doing this on my ride, but want to know what people are getting from it already first.
  • econti
    • May 2014
    • 1137
    The chip is a tune so no you do not need to tune the tune
    It makes more power
    It uses less fuel (at least in my experience) cause you don't have to flog the piss out of it all the time to move
    No negative side effects
    • jdt10768
      • Feb 2013
      • 484
      do it
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        I’ve got a sssquid chip with 19# 4 pintle injectors it is a different car now
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • jdt10768
          • Feb 2013
          • 484
          not to hijack, but what exact part number for the 19# 4 pintle injectors?
          Mustang? How much trouble to swap out? Did your mileage change at all?
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            I bought these ones iirc
            And yes my mpg’s dropped i go through a tank of gas once a week about instead of a tank every week and half but I don’t care cause the car is so much fun to drive now. Throttle response is amazing and it just moves out
            • e30s50dan
              • Nov 2008
              • 2076
              ^^ have you done any internal mods...cams,valve springs,etc?
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Nope bone stock engine. All ive done is cleaned up intake mess, cooling system and timing chain/guides with the chip and injectors. Eventually i’ll add a single mass flywheel.
                • jaredmac11
                  • Sep 2007
                  • 253
                  I *really* wanna pull the trigger on those injectors but I wonder how much of those improvements are from moving to dirty/clogged injectors to new ones?
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    Unless paired with a chip to utilize them you wont feel much difference. 4 pintle is better then one. You get better atomization of the fuel molecules which results is a more efficient burn which gives better power and throttle response. Them in and of them selves though wont really do much you need a chip to push it the extra mile. And if you get an sssquid tune. He will make the chip to utilize the 4 pintles where as others are an off the shelf tune unless you get in contact and tell them.
                    • youngmineeh
                      • Oct 2016
                      • 88
                      I have the same chip with 19lb injectors.
                      What mpg do you get now compared to what you had before? Mine's pretty low and I'm trying to see if the chip is the culprit.
                      But I do agree, it is way more fun to drive this car with a chip.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        I think its both. It has dropped but i dont care.
