If I dont have a charcoal cannister, do I need to substitute?
  • jaredmac11
    • Sep 2007
    • 253
    I dont have a charcoal canister. Do I need to plug the line or can I lead it to a DIY type filter or pick up an ebay filter and rebuild it?
    If I just plug the source of the line from the throttle body, can I make an assumption these fuel vapors will just burn off?
  • roguetoaster
    Biggus Tippus
    • 7830
    You can cap the nipple at the TB.
    Do not cap the other line or leave the valve unplugged. Zip tie the line/valve to a low point on the car and expect some fuel vapors once in a while.
    Unless your filter is rusted to bits you could refill it, or just replace it with anther similar unit.
    • jaredmac11
      • Sep 2007
      • 253
      Good input, and I would leave it open.
      Previous owner chucked the can and just left the line open. Its been fine thus far but it probably would be smart to complete the system. I noticed theres a connector for the PCV, it throw a code?
      • mitchlikesbikes
        • Dec 2013
        • 858
        i had mine disconnected for 2 years and never had a check engine light on my m20. not sure about m42 if that's what you have though
        IG: @mitchlikesbikes
        • roguetoaster
          Biggus Tippus
          • 7830
          I don't recall if it will cause a CEL to disconnect the valve, but it's certainly more ecologically friendly to connect it to the TB.
          • jaredmac11
            • Sep 2007
            • 253
            I agree. I dont drive the car as a daily but it would be good to properly manage the fumes.
            OOC, is there a cheaper, non BMW charcoal canister I can find? I would really like to get one that isnt 20+ years old but its hard to find a generic one that suits the right purpose.
            Not sure if anyone has successfully used one not from the specific car.
            • e30davie
              • Apr 2016
              • 1788
              Go to the wreckers and look around.
              • JimmyP
                • 394
                None of my E30s have them.
                Cap the port at the engine, if there is a solenoid take it off and throw it in a box.
                Take a small filter and put it on the line from the fuel tank.
                If I remember right there is some kind of yard appliance fuel filter that plugs right in to the line. I'll see if I can remember / find wat I used.
                I never have fuel vapors that I notice.
                The filters I have used on the fuel tank vapor outlet look like these.
                I'm a stickler about the only air going in to my engines is through the airbox inlet.
                Jimmy P.
                87 E30 M3 Prodrive British Touring Car
                88 E30 M3 Zinnoberot - Garage Queen
                88 E30 M3 Lachsilber - SCCA SPU #98
                92 M Technic Cabrio - S14 Powered!
                98 318Ti Morea Green
                04 Ford F350 Dually Tow Machine
