M42 Overheating...another one
So I replaced the fan clutch and the issue persists. Tried bleeding the system and the second it bled, it pressurized and a coolant leak happened at the bottom of the expansion tank. Same as seen in the picture in this thread https://www.r3vlimited.com/board/sho...nk+leak+bottom
Looks like I have an air leak with the tank. Ordered a new one but wanted to know, is there a way to drain just the tank and reuse the coolant (I know I know). Just don't want to do a full flush then realize I have more air leaks in the system and have to keep replacing the coolantComment
A "full" flush requires you to drain coolant from block, which you aren't doing. Coolant is cheap enough. Get what you need, to do the job correctly.So I replaced the fan clutch and the issue persists. Tried bleeding the system and the second it bled, it pressurized and a coolant leak happened at the bottom of the expansion tank. Same as seen in the picture in this thread https://www.r3vlimited.com/board/sho...nk+leak+bottom
Sent from my Pixel 3 using Tapatalk'91 318i (Alpine) - daily
'88 325ix (Zinno) - drive here and there!Comment
A coolant leak at the bottom of the tank can easily be a false positive as the coolant from the bleed screw leaks down there.
You can drain the system via the blue drain at the base of the radiator expansion tank. If coolant does not come out once the drain is cracked open you will likely need to completely remove the blue screw/drain and jab in the hold with something pointy to clear a blockage.
Just for fun, do the fan clutch test again and watch the brand new part fail. Basically, even new fan clutches that I have seen do seem to fail even with the engine at full temperature.Comment
Well there is a told you so, looks like I got a bad new fan clutch?
https://www.youtube.com/watch?v=LX923QRA2pE - after a 30 minute drive
https://www.youtube.com/watch?v=d8e7Dc9hwCU - just after turning it offComment
by the looks of the 1st video it's toastWell there is a told you so, looks like I got a bad new fan clutch?
https://www.youtube.com/watch?v=d8e7Dc9hwCU - just after turning it off1991 318is --- currently not road worthy
1991 318i ---- 308K - retired
so if you didnt get it like that did you glue fuzzy oil to the entire thing?Comment
