Full Throttle Hesitation between 4-5K?
  • E30-TourZing
    • Feb 2017
    • 145
    In advance, thank you for your contributions.
    - When 3/4 to Full-Throttle, my 318is has a hesitation around 4-5K. It pulls strong before and after the second it takes for the ignition to figure out what is going on.
    The plug wires were original to the car, so I changed them along with the spark plugs. It needed to be done, so now that this is still occurring I need to look deeper.
    I figure....
    - 02 Sensor
    - Crank position sensor
    - Cam sensor
    - Coil Pack
    Can anyone give me advice on what resolved their issue if similar to mine before I start spending money on sensors?
    My guess now is crank sensor. The issue is pretty consistent at 4.5K RPM's.
    Let me know your thoughts! Thank you,
  • roguetoaster
    Biggus Tippus
    • 7830
    No CEL?
    If not, it's time to test your cam/crank sensors, your TPS, and possibly the O2 sensor. Could also be any number of other issues from fueling to AFM wear.
    • E30-TourZing
      • Feb 2017
      • 145
      No CEL?
      Thank you for your response.
      No CEL,
      I have a new O2 sensor, and then go from there. Its likely the crank/cam sensor though. I will try some out when I go to the bmw wrecker near me.
