Light weight flywheel?
  • eu teo
    • 131
    #61
    i just finished my swap with the m20 flywheel and e21 throwout bearing and so on...
    i have an issue tho,
    when i go to start the car it make a grinding noise like when the starter turns over the engine until it starts do you guys know why?
    i have the regular m42 starter and i swapped he ring gear onto the m20 flywheel
    Please help
    87 325ic sold
    91 318i sold
    95 ///M3 sold
    02 325xi manual
    • eu teo
      • 131
      #62
      can any one help me?
      87 325ic sold
      91 318i sold
      95 ///M3 sold
      02 325xi manual
      • KenC
        King of Kegstands
        • 14396
        #63
        Is the starter lining up with the flywheel gear correctly?
        Originally posted by Gruelius
        • eu teo
          • 131
          #64
          yupp perfect.. pulled it out re installed (just in case) still does the same thing.. :/
          87 325ic sold
          91 318i sold
          95 ///M3 sold
          02 325xi manual
          • JoeyBones
            • 422
            #65
            isn't there a spacer or something that needs to be drilled out or something?
            • eu teo
              • 131
              #66
              ya but thats only so that the flywheel dosent touch the block..
              87 325ic sold
              91 318i sold
              95 ///M3 sold
              02 325xi manual
              • JoeyBones
                • 422
                #67
                oh, sorry...i haven't done this, was just taking a stab at this
                • KenC
                  King of Kegstands
                  • 14396
                  #68
                  Your flywheel bolts arent rubbing, are they?
                  • eu teo
                    • 131
                    #69
                    the noise is only when the starter is cranking... after car starts it runs perfect...
                    87 325ic sold
                    91 318i sold
                    95 ///M3 sold
                    02 325xi manual
                    • Boosted E30
                      • Dec 2009
                      • 288
                      #70
                      Try loosening the starter bolts a little bit then start/turn over the engine then retighten the starter. Somtimes that will fix the problem.
                      Also dumb question but did you make make sure they pressed the right ring gear on to the flywheel??? Not that they removed both ring gears and pressed the wrong one onto the flywheel.
                      Or did you make sure the starter gear and ring gear teeth mesh properly??
                      • eu teo
                        • 131
                        #71
                        i checked the ring gear and they installed it correctly i even checked to see if the ring gear slips on the flywheel bit it dosent..
                        could the starter have gone bad?
                        5 months ago i pulled the trans out and the car been sitting the whole winter with out a trans and once the weather got nice i installed everything back up..
                        car starts but makes loud noise from starter while cranking..
                        87 325ic sold
                        91 318i sold
                        95 ///M3 sold
                        02 325xi manual
                        • Boosted E30
                          • Dec 2009
                          • 288
                          #72
                          Ok your not understanding what im saying,
                          Did you make sure that the starter pinion gear and flywheel ring gear mesh before installing???
                          It could also be your starter crapped out but i dont know how that would work if its not being used.
                          Also if they pressed the ring gear onto the flywheel to far and the starter is not meshing completly when your cranking the enigne over.
                          • Victell
                            • 1083
                            #73
                            Why not just have a machine shop lighten the stock m42 flywheel? Sounds the simplest to me, but there must be a reason people arent doing this?
                            • eu teo
                              • 131
                              #74
                              its the original ring gear so its meshing perfectly..
                              the m42 flywheel is made of two parts that are put together to reduce vibrations for the engine thats why its called dual mass flywheel
                              87 325ic sold
                              91 318i sold
                              95 ///M3 sold
                              02 325xi manual
                              • e304me
                                • Feb 2006
                                • 1374
                                #75
                                Originally posted by JiXer
                                9.5 is REALLY light. It will rattle and idle rough with that light of a flywheel.
                                I have an 8.5 and there is only slight chatter in neutral, not really even chatter. Just a very slight increase in noise when the clutch is not depressed in N.
                                My idle is really good, except when I put a heavy load on the electrical system the engine dips 150rpm or so.
                                I love the flywheel
