Oil Leak AHH!!
  • RedHoodRidah
    • Feb 2006
    • 1096
    Oil Leak AHH!!
    I have a bad oil leak some where around the oil filter housing. I am losing about a quart every 2 days. Could it be the oil filter housing thats bad or maybe the gasket? First I thought it was from the oil sensor thats located on the oil filter housing but as I checked around the front area near the belts its leaking more. Can someone help me out with this issue?
    92 Granite Silver Vert
    M60B40 5spd
  • Teaguer
    • Sep 2004
    • 6167
    First you really need to determine where the leak is originating from .
    You can start by taking the car to the carswash and blasting the front of the engine and the oil filter housing area as well .
    Or you can also use a few cans of brake clean for the same results .
    Then after driving it a day or so keep checking to see where the oil is coming from .
    • scabzzzz
      Estado de mierda de encargo
      • 6870
      Correct me if I'm wrong, but I think that means its on its period. My girlfriend does the same thing. Its normal.
      • RedHoodRidah
        • Feb 2006
        • 1096
        I will try that. But it really doesn't seem to be coming from anywhere else but that area. Its dripping down to the oil pan which is what I thought was the problem at first. The oil isn't dripping down from the head neither its just coming down from the oil filter and straight to the floor. I have changed the oil filter cap ring thinking it was that since it was full of oil around it.
        M60B40 5spd
        • ian e30 318is
          • Mar 2007
          • 1808
          try replacing the seals. i just put in a new oil filter which came with replacement seals.
          1991 LS1 Swapped 318is
          Instagram:
          https://instagram.com/saltybeast/
          LS Build Thread:
          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
          • RedHoodRidah
            • Feb 2006
            • 1096
            Everything is all set. The problem was the oil filter housing gasket, the o-ring and oil pressure switch. Everything was replaced and now im oil leak free .:knock on wood:
            M60B40 5spd
            • enzo
              • Jul 2008
              • 73
              Did you do this yourself? How hard was it? Do you recall what parts you needed?
              Now: 1991 318is Diamond Schwartz ;)
              Then: 1990 M3 Brilliant Red (sold) :(
              Then: 2002 330i (sold) :grin:
              • RedHoodRidah
                • Feb 2006
                • 1096
                Yes Its very easy. Just remove the air box and such, Remove the alternator belt and alternator and you will see the bolts right behind there.
                Just looking up the Oil filter housing gasket. Should come with the gasket and little O ring seal. I will also change the oil pressure switch as well.
                OIl will spill out btw so be ready.
                M60B40 5spd
