M44 into an E30
  • Joe318is
    • Sep 2005
    • 6451
    Good deal! This fuckers going in pretty soon!
    Originally posted by vlad
    • dark_islight
      • Jun 2005
      • 41
      M44 Swap
      Are there any updates on the m44 swap? I have the same dilemma whether to rebuild my tired M42 (360,000km no oil pressure and making loud clatter from the timing chain cover) or the M44 which I can get easily.
      dark_islight
      _____________________________________________
      • Joe318is
        • Sep 2005
        • 6451
        Oh. it was not an M44, when i picked it up i noticed a '93' stamped on the back of the head, so it was an M42.
        Swap the pan, intake, and accesories. Put it in one weekend and its run perfect ever since.
        • E30nate
          • Oct 2007
          • 1050
          if you are looking for an m44, be carefull if you are looking at a 95 yr model as they switched from the m42 halfway through.
          • ethree
            • Aug 2007
            • 1213
            What about running the m44 with the ecu, just swapping the pan and manifolds?
            How much is different if swapping into an m20 car?
            • kylebes1
              • May 2004
              • 2804
              I just made a post on m42club about this swap... I would like to see if there is any more knowledge here.
              my 318is is a daily driver. Engine rarely goes past 4k, but with 200k it is tired and NOISEY!!! So I started looking into the m44 conversion.
              The easiest way to do this conversion is a simple short block swap. Retain the e30 intake, harness, sensors, oil pan and accessories. The displacement change is an increase of .1L. I believe this would be a negligible change, though some feel a complete remap is necessary.
              The only real question that came to mind for me was the difference in the cam sensor design. The e30 m42 and e36 m44 use different sensors. What I can tell, however, is that if this sensor is not functioning the ignition goes into wasted spark, where the ignitions are paired. This simply means you get one piston firing when it should and a paired piston firing when it's on the exhaust stroke- meaning it is wasted and affects nothing. Correct me if I am wrong.
              Now the second thing that came to mind regarding this cam sensor was that it must also work with the fuel injection. Well come to find out the fuel injection is already firing in pairs. So the injection stays the same, and the ignition goes into wasted spark mode. I venture to say it is safe to kill the cam sensor...??...
              Will someone please correct me if I am wrong? I am tired of hearing the terrible volvo b230f under my hood! I want a lower milage, smooth BMW engine again!
              • kenika65
                • Aug 2007
                • 1336
                Then please rebuild your M42 and call it a day.
                1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                • kylebes1
                  • May 2004
                  • 2804
                  A low mileage m44 is easy to come by and far cheaper than rebuilding a worn out m42... that and the m44 has a better head design
                  • Joe318is
                    • Sep 2005
                    • 6451
                    try to find an early e36 318i[s] m42, 93 or before. the one i found had 50k on it. car runs perfect now
                    • EN318isPDX
                      • Oct 2007
                      • 4373
                      I disagree. If all you care about is MPG than get a geo
                      • kylebes1
                        • May 2004
                        • 2804
                        You are confused.
                        • kylebes1
                          • May 2004
                          • 2804
                          The late m42 has the improved valve train that I was after... but low milage is good either way.
                          • EN318isPDX
                            • Oct 2007
                            • 4373
                            You are confused.
                            M42 Top end > M44 Top End. Your sig is a disgrace, do you run 87 octane or 92 octane
                            • kylebes1
                              • May 2004
                              • 2804
                              I was under the impression the m44 had a better valve train design... though very close in design to the the m42, I was thinking improvements were made. I cannot find where I read that, but both engines are new to me, so information is welcome. I would have to say info would be more welcome than short replies that have no value other than what seems to be a personal opinion.
                              I use premium gas with a Mark D chip. Not sure why my sig is a disgrace... do you get better than 32 mpg? If so I am open to suggestions as the more the better...
                              As for getting a geo... the 318is has been a really fun car, as anyone would tell you, and has the added benefit of really good fuel economy. A good compromise over having a geo that I would never want to be seen in public in...
                              Help me understand what you mean, Mr. EN318isPDX.
                              • golde30
                                • 11464
                                uhh m50 swap? why even waste time putting in an m44... m50 swapped guys are getting decent mpg, equal to an m42 but more power...hello?
                                IG: @Baye30
