Engine rattle *video*
  • josephb983
    • Nov 2007
    • 60
    What could be causing this noise? It sounds a lot louder than in the video when engine is frozen, like -10F. Goes down significantly once engine is warmed up.
  • Jak
    • 62
    It sounds like the chain tensioner doesn't have any oil in it yet. Either that or its bad.
    • BBY1104
      its not the the water pump making noise is it?
      • josephb983
        • Nov 2007
        • 60
        How would I be able to check the water pump?
        • 2002maniac
          • 4260
          sounds like a loose timing chain to me. have you ever replaced the tensioner? do it, they are cheap.
          • josephb983
            • Nov 2007
            • 60
            I don't think so, the pump was changed in recent times. Or so the previous owner said.
            • josephb983
              • Nov 2007
              • 60
              I changed the tensioner. The noise didn't improve.
              Tonight I shot another video, this time with the engine warmed up:
              Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
              If you run this right next to my original video in the thread, you'll hear the difference when the engine is warm.
              • Jak
                • 62
                That sounds exactly how mine sounded. I tried the tensioner first and it didn't make any noticeable difference either. I ended up doing the whole timing chain. Pull your valve cover and look at the gears. If they have pointy teeth its time for new ones.
                Here is the link to some pictures of mine before and after.
                • josephb983
                  • Nov 2007
                  • 60
                  http://www.r3vlimited.com/board/showthread.php?t=96062
                  So changing the gears stopped all the noises? I already know my top gears look as yours did. Do you have snapshots of the lower gears on the crankshaft too? Did they look pointy, or were the gears actually warn down? I'm gonna be taking mine apart pretty soon here, to see. Thanks for taking the time to post those pictures! :up:
                  • Jak
                    • 62
                    Yes, after i replaced all my gears and guides all the noise is gone. Here are some picks of the lower gears but im not sure they were the cause.
                    The deflection gear still looked pretty much new and the crank gear wasn't nearly as bad as the cam gears. Since the cam gear have a much larger diameter I would think that any wear on them would make a much larger difference than on the lowers.
                    • kenika65
                      • Aug 2007
                      • 1336
                      Great information thanks for the info.
                      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                      • G60 CAB
                        • Jan 2008
                        • 185
                        How much did those new gears cost ya?
                        83 500 SEC.....aired and then some
                        87 420 SEL......on 20" D's
                        99 M3..............twinscrewed and wallet hungry
