So, I've been trying to get my new 318i that I purchased from Majikal running, but the damn thing has been giving me a few issues.
First off, I just replaced the fuel pump, yet when I crank it, it does not prime. Pull the middle relay off, and it's getting power to both #'s 30 & 86 on the relay. Went to check the power to the pump and it's not getting anything. Jumped #30 & #87 and heard the pump turn on. Then I replaced the fuel pump relay with a known good one, and the problem persists.
Any idea what might be causing it to not turn the pump on when it cranks? Bad ECU, crank sensor?
I'm pretty sure my Ignition coils are shot, but that shouldn't affect the fuel pump turning on, no?
Thanks for any help/suggestions/input.
