coil over plug kit??
    I have an extra valve cover so i would be okay but, do i need to drill holes and such?
      No drilling necessary. The threaded rods screw into the existing holes in the valve cover.
        Originally posted by BBY1104 View Post
        hmm so are these m52 coils?
        I am thinking about getting this setup.
        So the coils screw to the bracket? and the bracket just pops in the valve cover and sits there right? Or do you have to screw and or bolt bracket to valve over?
        The Coil On Plug plate bolts to the valve cover with the supplied threaded rod and hardware provided. It's a clean setup.
        In the picture I provided of the turbo motor you can see the nut/washer and the top of the threaded rod between coil 1 and coil 2.
          got it thanks
            e30pq's kits are great!
            Here's mine installed..
              Does anybody know if you can use s52 coils?
              1985 325e 2.8 Turbo VEMS
                I know its a bit old, but will better high performance coils benefit the motor at all?
                [/url]
                Team USA Wrestling 67KG
                  are these used coils I'm assuming? I think I got a coil shorting on my M42, plus I want to get new wires, so this might the route I'd like to go.
                  Thanks
                  Sold.......again.
                    Originally posted by e30pq View Post
                    We have a new batch of COP kits available.
                    The kits include top grade hardware (no home improvement store stuff).
                    $185 w/coils (shipped in the US)
                    Coils are used but tested prior to shipping. One coil is modified to fit in Cylinder 1.
                    $80 w/o coils (shipped in the US)
                    I´m interested in this mater...
                    Will you send it overseas? (Cost for S&H to Portugal)
