Ok, I bought a e30 318. I knew it had a bad head gasket. The car over heated and had bubbles coming through the expansion tank. So i had the head resurfaced and put on a new headgasket. I did the job on a budget.
After getting the job completely done i started it and the motor has a very loud knocking or Clattering sound. Above 3000rpm it goes away and the motor sounds really smooth. I have 20-50 castrol motor oil in it. I check timing and it seemed ok. i cant figure out the sound. it wasnt there before i did the work.
I drove the car for the first time a good distance in 100 degree weather about 5-8 miles. It stayed just a tick over the 1/4 mark on the temp gauge. Today its the same weather maybe a bit cooler and it started to over heat when sitting at a light. When moving the temp goes down. I let it almost get to the 3/4 mark. Then i shut it down and then i let it cool down. I am just running water. I opened the system to bleed it and the screw broke off. so this is what i used in place of it. I opened the cap and it was bubble but i am pretty sure it was just boiling because i just shut it off.
Any help would be great. I am so frstrated with this car. I am used to working on m30/m20 motors and really need this car to work. I am with out a car for work or school. Feel free to call me if you would like to talk ideas on fixing this. My name is ryan. MY phone number is 408-476-4780.
