IE Poly Engine and Tranny Mounts
  • EN318isPDX
    • Oct 2007
    • 4373
    Finally got my IE Poly Bushings in and so far my opinion of them is.. STIFF! Do not recommend for anyone who wants to drive a quiet car. I enjoy feeling the vibrations of my motor. I feel more in tune with it.
    Took my pics in the dark so they are crap. Hopefully i can get better pics of the finished product today when its more light out! Ill post a low quality teaser here
    • kencopperwheat
      King of Kegstands
      • 14396
      You would have a LOT less vibrations with rubber tranny mounts... that's where you're getting most of it from.
      Originally posted by Gruelius
      • EN318isPDX
        • Oct 2007
        • 4373
        Yes I know, i had rubber ones before hand and i enjoy these alot more
        I can really feel the difference in neutral (can feel motor mounts) and in gear (can feel driveline and tranny)
        • wolfgangstbd
          • 960
          haha i like ur style u dont bitch at all... i always hear noise/ruff for all these stiffer parts theyre really not that bad so if ur young go for it but if u dont wanna deal wit the noise just harden the fuck up imo but to each his own :)
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            i'm young and there's some noise i rather not deal with, so that's why i went rubber tranny mounts and poly engine mounts
            • charlesmarseille
              • 2
              hey guys, how do you know if your mounts are to be changed? if they failed, and what about the homemade honda style poly bushings?
              • EN318isPDX
                • Oct 2007
                • 4373
                Failed engine mounts can let your engine rotate far beyond acceptable limits. A failed Engine Mount will usually allow contact between the fan and the fan shroud.
                No idea what to say about the last part.
                • strad
                  • Jan 2007
                  • 241
                  When your oil pan is resting on the crossmember because your mounts have collapsed. Or you put a jack under the motor or transmission, lift up slightly, and you see the mount separate where it's been sheared in half. That's a rather crude example of a few ways you can tell.
                  The current fleet:
                  1992 325ic: 148k-171k miles
                  1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                  1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
