engine idols weird, help me please
  • amiclea
    • Nov 2008
    • 17
    i was driving in my 318is redlining gears, and i put it in neutral as i was cruising down a hill, and my car stops, so i restart it again and it chokes at idle , revs up, chokes, an so on. if i gave the car gas it was fine, i drove it home fine, but at stops i had to make sure i reved it in order to not stall. this morning i cleaned out the maf and icv and i thought the idol problem stopped, but as i let it idol for a few minutes it starts to choke a little again (not as bad as before) for a bit then slowly it goes back to a normal idol and it happens again. i checked the check engine with the gas pedal test and i read it as 1222, which is "Lambda Control 1". i thought maybe it the icv, vacum hoses, or the maf sensor, and maybe even the car is running rich. it seems that the problem only exists at idol. i need help !:(
  • devonjordan
    • Jul 2006
    • 2386
    Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    Help a brother out, buy your detailing products here...
    • FredK
      • 14764
      I would check for a HUGE vacuum leak somewhere. Likely there's a split hose underneath the intake manifold.
      • amiclea
        • Nov 2008
        • 17
        Originally posted by devonjordan
        haha my bad, thanks for the help
        • EN318isPDX
          • Oct 2007
          • 4373
          lol
          m42 have a stupid amount of vacuum lines.. Check M42club for "mess under intake"
          • amiclea
            • Nov 2008
            • 17
            could it be the throttle position sensor? a friend checked with a voltage meter and the voltage dumps way low and is very unstable, he was almost postivie that that is what the problem is.
            • devonjordan
              • Jul 2006
              • 2386
              Seriously though, the guys above are right. M42s suck for vac lines, I eliminated the mess, it blows!
              • amiclea
                • Nov 2008
                • 17
                alright well i cleaned out the icv, and that had a major cracked hose connected, so i taped the cracks for now, i turned it on and it was a little better, so i unplugged the tps and the battery replugged and it was the same, (better than the first night), so i was frustrated and took it out for a hard drive around the block, came back and it idles 10x better! it still slightly drops a little like every minute or so and tries to compensate for it, but its not noticeable. but it might have been those vac lines, so im gonna go ahead and replace all of them asap and ill see if it idles perfect once more.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  M42 is both prone and sensitive to intake leaks. There's a thread about cleaning up the "mess under the intake." Check it out before you start replacing hoses.
                  Originally posted by Gruelius
                  • wolfgangstbd
                    • 960
                    just in case it isnt your vaccum lines. my car had rough idle and gradually got worse and my car had trouble starting and wouldnt run for more than 30 sec. turned out to be a bad fuel pump
