Oil leak from chain tensioner cover
  • kencopperwheat
    King of Kegstands
    • 14396
    I'm getting a small, steady oil leak from my timing chain tensioner cover on the head. No, it doesn't need to be tightened any more (I think it may have been over-tightened a bit earlier in its life). Is there anything I can do to stop the leak? I've thought about using a bunch of teflon plumbing tape on the threads.
    Originally posted by Gruelius
  • EN318isPDX
    • Oct 2007
    • 4373
    The joker who owned my car before me stripped out the oil pan and the valve cover, i plan on buying a bunch of helacoils and fixing it that way. At least thats how ill do the valve cover. I'm gonna swap the oil pan.
    • kencopperwheat
      King of Kegstands
      • 14396
      ... ok.
      Anyone have any suggestions regarding my original post.
      • EN318isPDX
        • Oct 2007
        • 4373
        The joker who owned my car before me stripped out the oil pan and the valve cover, i plan on buying a bunch of helacoil and fixing it that way. At least thats how ill do the valve cover. I'm gonna swap the oil pan.
        Do you not have google or you just don't know what helacoil is?
        This statement is why i recommend you helacoil..
        • kencopperwheat
          King of Kegstands
          • 14396
          I'm not helacoiling it. It's like 20mm and pretty shallow. Plus I'd have to pull the engine to get a proper angle on it.
          • gearheadE30
            • Jun 2007
            • 3734
            You can always pull the cover, buy a new gasket and some permatex or similar liquid sealer. That has fixed almost all of my leaks so far, because the paper gaskets sometimes don't work 100%.
            Project M42 Turbo
            • kencopperwheat
              King of Kegstands
              • 14396
              Paper gasket?
              I've ordered a new washer/gasket for it... hopefully that does the trick.
