Turbo m42??? I'm sure it been dicussed & done
  • wastedincome
    • Aug 2004
    • 906
    Well, I'm really "ALL SET" on reading through a million threads pulled up by the "search". Any how I've been itching to pull the m42 from my vert in favor of a M-S/5X BUT since company's like 666 have manifolds etc for the m42 I'm kinnda considering keeping the m42. Whats the latest updates on this setup?? Should I do it?? Whats kind of HP can come from a mild built&boosted m42??????
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
  • ZM Blue Devil
    • Dec 2006
    • 13836
    metricmechanic... just do it!
    Levent
    %20levent@gutenparts.com
    Ladies:
    • atomic
      • Jun 2007
      • 5691
      Danny has a extensive low budget m42 turbo build thread (beware some, ok alot of post whoring) Here
      • kronus
        • Apr 2008
        • 13032
        in before Danny?
        cars beep boop
        • BenM
          • 2184
          My dad's car:
          Lots of $$ invested.
          Originally posted by BillBrasky
          E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
          1991 318i Alpine II - S50/5-lug swapped - track car
          1989 325i Cirrusblau - Daily
          1970 2500 - Malaga over Grey Cloth
          2012 F350 6.7PSD
          • Liam
            • 753
            M42 right out of the box doesn't take too well to boost. It does require extensive modifications to work really well.
            I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
            • wolfgangstbd
              • 960
              alot of people have done all stock internal running ~8psi boost... just kinda "risky" but if you really want to know go on
              • Danny
                • 14216
                Wut
                • wastedincome
                  • Aug 2004
                  • 906
                  Originally posted by BenM
                  My dad's car:
                  Nice set up....What kind of WHP is it making?? Thats 666's intake and exhaust manifold right?? I'm sure it wasn't cheap but whats a Ball park figure on the turbo set up??
                  CURRENT STOCK LIST:
                  • cepa318is
                    • Mar 2008
                    • 228
                    I think the intake and exhaust manifold alone from 666 is like $2000. Its not going to be cheap.
                    • BenM
                      • 2184
                      Here are some of the engine specs on it:
                      Metric Mechanic 2.0 Forced Induction Motor (Big Bore Forged Pistons, 8.5:1 Compression Ratio, MM Intake Cam)
                      666Fab Exhaust Manifold, Intake Manifold, W/A Intercooler (Tank in the spare tire well w/ marine application bilge pump) 3" Exhaust and Downpipe,
                      1.8T OBD-II Passat Throttle Body and Idle Control Valve
                      Link G2 Standalone Engine Management System
                      GM 3.5bar Map Sensor
                      60lb. Injectors
                      Aquamist Methanol/Water Injection System
                      ZF320 5-speed
                      M5 240mm Clutch
                      MM rebuilt 3.07LSD (for regular driving)
                      MM 50% 3.25LSD (for track events)
                      Here is the power it made on a Mustang Dyno w/ 93 octane-
                      @10lbs. w/out Water Injection - 247WHP
                      @15lbs. w/ Water Injection - 317WHP
                      @18lbs. w/ Water Injection - 347WHP
                      The car is a rocketship and is able to wind out to 7800rpm.
                      2012 F350 6.7PSD
                      • wastedincome
                        • Aug 2004
                        • 906
                        60lb. Injectors
                        Can you give a cost quote on the above items ??? Cost of the MM engine would help but I'm sure I can find out w/ some leg work
                        CURRENT STOCK LIST:
                        • rThor432
                          • Feb 2007
                          • 3907
                          Just an estimate, but the stuff he mentioned should be $11-$12k for everything.
                          (let's see how close I am)...
                          Motor-- $7k
                          Manifolds-- $2k
                          Turbo-- $750
                          Standalone-- $500
                          Gearbox-- $500
                          Clutch/pp/flywheel-- $1k
                          Adds up fast..
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Motor-- $7k
                            Manifolds-- $2k
                            Turbo-- $750
                            Standalone-- $500
                            Gearbox-- $500
                            Adds up fast..
                            WAY too much dough for only 350 at the wheels
                            Originally posted by Gruelius
                            • BenM
                              • 2184
                              If I look back at the receipts, its closer to 20K.
                              $5k for the manifolds, w/a intercooler, exhaust, downpipe
                              $9K for the engine, zf transmission, shortened driveshaft, some other pieces
                              $5K for GT2871 Dual Ball Bearing Turbo, Link G2 Standalone, Tial 38mm Wastegate, Injectors, Installation and tuning, other stuff
                              Add another $1K for good measure for other various expenses parts that were needed. Plus the suspension w/ coilovers and 5-lug stuff is easily another $4K.
                              The car has $25K into it easily and yes the costs add up quick!
                              To add to that, the car is getting the motor yanked this weekend. The dreaded milkshake oil showed itself, and after a compression test cylinder #4 was down on compression due to a blown headgasket.
                              HTH,
                              Ben
                              2012 F350 6.7PSD
