New Accelerator cable. How much play should it have?
  • IS300E30
    • Apr 2009
    • 408
    I assume it should not be extremely tight?
    Please advise, thank you
  • digger
    • Nov 2005
    • 6216
    Just a little slop, the cable should not be taught, the throttle is supposed to sit on its stop
    • ADEN
      • 620
      Digger has given you the answer..
      One final check...After adjustment to the new cable let someone floor it and you look at the butterfly and make sure it opens 100%.
      Too much cable slack or something behind your pedal will prevent it from opening the throttle 100% i guess.
      Good luck..
