e28 manual trans to e30
  • skitzy777
    • Jul 2016
    • 57
    So i just bought an e28 525e with the 2.7 in it. I plan to use my current 731 head and swap it onto that motor, and swap that motor and trans into my e30.
    What parts can I use from the e28 to assist in the manual swap? im thinking Master cylinder, slave, clutch pedal, clutch lines, possible drive shaft?
    Cheers
    -E30 323i 1983
    -Honda CB250n 1980
  • 82eye
    • Jan 2009
    • 2106
    how much you use depends on what's in the e30 now. i'd go on realoem and start cross-referencing part numbers.
