Did you pre-load the the CSB?
Why does my Drive shaft still KNOCK!?
So i looked up what preloading the csb is and no i did not do that. i simply bolted everything together and when the shaft was in i just pushed up toward the car so it would be as straight as possible. is it known for it not to be preloaded to make noises? i will do this tomorrow and see if it helps. i wrather that was the problem then having to buy something else again. its pissing me off now. thank youHaving a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gayComment
I fixed it. It turned out to be that the teeth were not alinned. so i took it apart again and put it back together popperly and now everything is good. thanks for your help everyoneHaving a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gayComment
