I've had the car now for about 8 months, I drained and refilled the transmission oil once. The oil level didn't seem abnormally low.
I noticed here and there a few drips of oil, only after driving the car though, not when sitting. The car is now getting (alot!) of work performed on it, so I'd like to see where the trans is leaking from so I could fix it. '90 325iC. At first it looked like the drain plug, but then it appears to be really heavy around the tail shaft. Would this be the output shaft seal? It also looks like it could be coming from the area where the selector rod goes into the trans. Anything common? Depending on what it is, could it be replaced with the trans in the car? I only ask because I know if I pull the trans I'll want to do a whole lot more work while it's out as well.
