My auto tranny died AGAIN
  • Pierre
    • 25
    89 325i
    Does the tranny off an early E34 M20 fit?
    Thanks.
    Pierre
    91 318is, 84 323i (S52), 69 2002 (M20), 74 tii, 76 530i (3.3) 79 323i, 96 318ti (S52), 2001 540i (6sp) 2002 330i (wife) 2002 R1150RT, 2003 525iT.
    O==00==O
  • paulkeith
    • Apr 2009
    • 146
    wait, so, let me get this straight.....
    this happened before, and at that time you paid money to put another automatic in?
    ....woops
    forget the e34m20 motor. DO. A. MANUAL. SWAP.
    pull: '02 F-250 7.3L 6SPD 4x4, Chipped, Straightpiped, BFG MTKM2.
    turn: empty stable. lame.
    • Pierre
      • 25
      This car is not for me to drive
      The only reason I have it is because it's an automatic.
      I have several other manual Bimmers including a 91 318is.
      I bought the car 3 years ago, and the tansmission failed 18 months later. I swapped it and the current transmission lasted another18 months. Not bad for a $50 tranny and three hours to swap it in.
      I have access to an E34 92 525i transmission is good shape for $50. Will it fit? If it will give me another 18 months, I would be happy. Or I may swap it in and sell the car.
      Pierre
      O==00==O
      • smooth
        • Apr 2005
        • 1940
        I've got an auto tranny in Vista if you want it. It leaks like crazy, but otherwise goes through the gears fine. Figure out the leak and you should get plenty of miles out of it.
        Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
        • Pierre
          • 25
          Do you know where it's leaking from?
          Pierre
          O==00==O
          • smooth
            • Apr 2005
            • 1940
            Maybe around the filter if that makes sense. I didn't pay attention to what my uncle said when we pulled the block and tranny :)
