Where can i bye a reinforced flex disc?
  • joacim
    • 9
    Where can i by reinforced flex disc for my e30.. m20.. :)
    Does anybody know? have seen them in aluminum (cant remember where), but would like to have poly or something softer..
    Thanx
    Joacim
    Norway
    What is wrong with using the OE guibo?
    • joacim
      • 9
      It dosent last long.. 1 or 2 races.. its for a drift car..
      but i gess, if i reinforce the guibo something else will take the hevy load and break...
      Sorry for my bad english :P
      • E30_fiend
        • Apr 2006
        • 7348
        if you are blowing through guibos the its not because of your racing its most likely because of your driveshaft u-joints. You possibly need a new drive shaft AND flex disk. And while youre at it, get a new center support bearing too.
        Taylor
          That is an awfully short life for a quibo. Unless you've done something to dramatically increase the engine output, I'd wonder if there might be some other problem that is destroying the guibo. Like bad transmission of motor mounts, bad CSB, or bad drive shaft.
          • joacim
            • 9
            Taylor
            thanx, i have changed all these things :)
            Got AKG enging and tranny mounts, stiff.. no flex..
            its not for a original m20, its for a turbo engine, long spec list! and hardcore use :pimp:..
            I will just try another oem one, and se if its only bad luck that have given me the problem..
            thanx
            • txtorquemade
              • 1758
              Ive heard of using a guibo from a e34. Supposed to be sturdier, but just hear say. Ive never done it. Good luck with whatever you choose bro.
              sigpic 1987 325is
              • mattdk318i
                • Jun 2006
                • 3953
                You might try locating a large flange driveshaft and a M5 Guibo. You will need to swap the output flange on your trans though
                  • 34847
                  also make sure you put it in the right direction. if you put it in backwards it doesn't last long.. I had one die after 5k of normal driving because of that.
