fluid? selector? bushings?, syncros? on not of the above
  • colombacho
    • May 2007
    • 391
    the problem is on an 84 ETA, car runs like a charm, but 2nd gear is not engaging when accelerating, it grinds the gears like a mf. So what i am doing is going from 1st to 3rd and compeately skiping 2nd.
    Whenever it 2nd engegaes i have to go slow and really push back the lever and kindda jiggle it while still pushing back on it. then it kicks in, so:
    A:bushings
    B:syncros
    C:fluid
    D:bent selector
    or
    E:none of the above, new suggestion
    will be giving the car to my dad, he needs a car to move arround and dont want him struggle with it.
    thanks
  • nickpdx
    • 679
    Try options A and C (use Redline MTL), more than likely that should take care of the problem.
      Grinding only when trying to engage 2nd is B above. The logical fix is to replace the transmission with one from a salvage yard.
      • colombacho
        • May 2007
        • 391
        ^the suxs, i was hoping fluid and bushings. will drop this weekend and see what comes out.
