I need to remove the dampner from my driveshaft as my shifter is hitting it.
I really do not want to drop my full exhaust. As the bolts to remove the cat part from the manifold are really frozen. I was wondering if I hit the crap out of the dampner with a mallet till it and the studs pull away from the flange and then slide it off instead of heaving to drop the driveshaft.
Or is this a stupid idea and I should suck it up and bust some knuckles removing the exhaust.
