can I ? or do I need anything special
can I change my center support bearing my self?
I'm doing it right now. No special tools needed other than circlip pliers. This project has been a bear though- working under the car completely on jackstands and trying to break decade+ old bolts with hand tools is really not fun. My center driveshaft clamp took a plumber's wrench and just about the full force of my leg to break free. Seriously not a fun project, but totally doable. I'd recommend compressed air tools. -
are you mechanically inclined?
if so do it
no real special tools required, snap ring pliers a must though-Andy
In almost all cases, a failure of the center support bearing will be due to binding u-joints in the drive shaft. Replacing only the CSB is possible, but the replacement will have a short life until the drive shaft is replaced. A reman drive shaft will come with the CSB installed.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
dropping the exhaust is the hardest part of doing this, i would suggest presoaking the header nuts with liquid wrench or wd40 for a day or two before diving in on this. Listen to Jlevie get a remanufactured DS, I did only the CSB and I can still feel a vibration coming from there, the u joints were stiff lol i thought it was a good thing.
'89 Alpine S52 with goodiesComment
