I'm in the market for a trans and someone just offered me a 260 that clean enough to eat off of but like I sai its a 260 my car takes a 240. Is it a direct bolt on? is it even possible?
260 in 318?????
your 240 is shorter and you bell housing is shorter. So yes it will bolt right on to the motor, you could run the larger m30 clutch but you will have to find a shorter driveshaft with a large guibo -
are you talking about a g260 from an m20?
that will not work at all im talking about a g260 from an m30Comment
