i flywheel e tranny
  • Red88
    • Nov 2008
    • 1161
    i flywheel e tranny
    I'm going to be putting an i flywheel on a 2.7i, with the transmission that came with an e. I would use an i clutch kit with this setup behind an m20, correct?
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
  • E30_fiend
    • Apr 2006
    • 7348
    correct. The eta has a dual mass flywheel IIRC so if you get rid of that youll be golden. my buddy used an eta flywheel on his i motor so I am sure they are interchangable the other way around.
    • Wh33lhop
      • 11705
      Clutch has to match the flywheel, eta tranny will work fine with the i clutch/fw.
      :( Why in god's name would he do that? Broke and had an eta clutch lying around or something?
      paint sucks
      • E30_fiend
        • Apr 2006
        • 7348
        Because his i motor was an auto when he did the swap to 5 speed and the tranny/clutch/flywheel setup he had was from his old eta. So rather than usuing the dual mass auto flywheel, he used the eta flywheel because it went with the tranny.
        • Red88
          • Nov 2008
          • 1161
          Thank you bery bery mucho.
          sigpic<< wrecked
          • Wh33lhop
            • 11705
            Auto tranny = no flywheel :p flex plate and torque converter replace it. But I get it.
            paint sucks
            • E30_fiend
              • Apr 2006
              • 7348
              eh! got me! At least you understood what I meant. haha
              • REVHARD05
                • Sep 2005
                • 250
                Question directed toward e30 fiend
                did he use the, Auto starter? what abouth the little spacer that came on the auto flexplate?
