Often when I disengage the clutch - particularly in first or second gear - without a bit of throttle to even it out, I hear a clunk from the back. It's almost as if the driveshaft is going back and forth.
The reason I added the throttle bit in there is that if I keep the engine revved up a little, it won't clunk versus if I let off the throttle completely then disengage the clutch. The second one causes the most "clunkage."
My guesses are a bad guibo, a bad differential mount, or just low fluid in the differential.
I know the differential is supposed to have a little play, but I think something is awry.
Best,
Pete
Best,
Pete
